I greet Mikrotik’s team, I have the problem with a rb750gr3 computer, which I installed the dude everything works correctly, but when I restart it, all configuration of the dude is lost. Now do update, same mode downgrade, likewise make all versions and do the same, you lose the configuration of the dude. It should be mentioned that nadamas does it with the dude, since if I make changes in the RB if you accept them.
solucisp,
Did you read the following topic: New device that supports The Dude server package: RB750r3 hEX?
Which Dude version do you use?
Thank you!
Hope you set the dude storage to external flash instead of the local ramdisk…
Have a look at my challenge with this:
http://forum.mikrotik.com/t/seems-some-firewall-settings-disappear-on-power-cycle/104681/10
I already put all the versions to have and when restarting only the configuration of the dude is lost, it currently has 6.35.7, but I also put the 6.39.1 and do the same …
I have not tried
So do it.
