Does anyone has The Dude 4.0-beta3 for x86?
The dude for x86 or routerboards is no longer available here: http://www.mikrotik.com/thedude
Are you sure ?
He was asking for the RouterOS package. Yes, we removed them, because they had major problems and people were risking with their config.
Ok, my bad.
Send me a PM.
I installed dude4.0beta3 on x86(routeros v6.21.1) but not work.
Appears as package installed and I see this in execution, but I can not enter from the web or from the client
The Dude doesnt work on RouterOS 6.x .
This is due to how execution has changed slightly in newer versions.
Dude works fine on RouterOS 5.x .
I could probably fix so it works on RouterOS but Id probably violate some licenses repackaging the dude x86 npk .. So not taking any risks. Unless Mikrotik would let me ![]()
I have it running under ROS 6.19/x86. Since we can’t get it running beyond that version (Upgrade to 6.20 → No response from The Dude; revert to 6.19 → configuration lost, time to rebuild the map.), we are stuck keeping this one rack-mount server spinning just for The Dude. ![]()
As an alternative to keeping that ROS/x86 server running just for The Dude, I was thinking about putting it in a VM. Can someone please direct me to basic instructions (my VM expertise is limited) on how to load the RouterOS ISO image into either Xen or KVM?
