Hello everyone,
I just bought CRS326 and I tried to install the dude server I downloaded the dude server ARM in dragged it into the winbox and it installed but when I reboot it disappears and have a massage in the log says "not enough space for upgrade and I have 480 MiB free memory I hope someone can help me.
Nice and clear title, we quickly understand what the problem is… and put it in the right section of the forum as well.
If you can’t figure out how to create a topic on the right way…
do you understand the differences between Memory and “Disk”?
Running Dude on devices should simply be removed as a feature, because users will just write their flash to death.
That’s not true, there are already too many arguments about it, I don’t want to re-explain it all over again.
An example over everything, I have a user manager on RB1100AHx2 (not the newest, but the 2009 model) that still works perfectly
and probably the user manager writes more data to disk than The Dude, and even if it writes less data, after 12 years it still works…
Where should it be run then? MikroTik have stated that they don’t recommend running it on CHRs (with V6 anyway - maybe they’ll fix it in V7 (if the underworld doesn’t freeze first)).
Back to the Windows version, like 3.6?
