Dear users,
I have one RB951Ui-2HnD router witch have two wlan, one is a “private” and the other one is a “guest” virtualAP. The guest wlan have a dhcp for a dedicated subnet (192.168.11.0/24), the private don’t have a dhcp, a dhcp server is running on a ADSL modem for 192.168.1.0/24 subnet. The private wlan have a WPA2 PSK authentication, the guest got a WPA PSK authentication.
I bought another RB951Ui-2HnD router and I want to extend the wireless signal of this two wlan, and if it is possible by not changing a configuration of the existing RB951Ui-2HnD router and his wlan-s.
I spend a lot of time looking for the answer, but didnt find anything adequate…
Can you suggest me something
Best regards,
Paolo
