the groove a-5hn as a broadband router...........
hi every one…
for 3 days ago and i tried to make groove a-5hn works as outdoor broadband router..lets give you an idea /
1- i succssefully established an wireless connection with ISP .
2- i set the pppoe in the groove and it worked fine.
3- i set dns,gatway,firwal,nat…etc as down
4- i successfully set the dhcp server to give the ip addresses
but the proplem is there is no internet
i will put my settings images.and ask you to help me if forgot somethings
Only thing that is standing out to me, would be to change the wireless mode to Station, instead of station pseudobridge.
An upload from /export compact would be useful.
You mentioned setting the DHCP server - did you mean client or server?
i did it .but still no internet
to let computers to get ip address from any mikrotik device you have to set the dhcp server .so any computer can connect to.
why not just use Station instead?I hope I’m not mistaking but you must use Station with NAT and pseudobridge in bridge mode when the AP is incompatible in some way.
my dare .there are nothing in mikrotik called as your saying(Station with NAT and pseudobridge in bridge )
The images above only show a fraction of the config so please upload the out from /export compact.
Any reason you are masquareding all traffic? Masquerading the output on the PPPoE interface makes sense but the first NAT rule above looks dangerous.
You can do this with one or two clicks, if you simply use Quickset. Open the IP of your device in a web browser, and Quickset will open. There you can choose “AP mode” and basically you are done.
actually .i dont understand you.how i do that??!!
do you suggest another nat firewal rule?
AP mode !!!
