The highest throughput <1Km PTP line of sight setup
So I’m going into a project where there’s a 600m PTP connection needed to pass as much bandwidth as needed. The cost is not a factor at all… I just want to avoid the $74k in construction costs for burying fiber. That being said, I’m really new to the Mikrotik wireless stuff. I’ve got a single back haul setup and 3 more in the works but I’m far from an expert.
If you had to setup a PTP link, disregarding cost, and wanted the most throughput possible, what setup would you use?
Many thanks in advance for whoever can help.
If there are any vendors on here, feel free to contact me.
matt at byrdits.com
Thanks!
RB800 + N will give you 200 Mbps aggregated if you use good antennas.
OK which cards and which antennas?
R5SHPn? R52Hn?
you can use 3x3 MIMO
http://forum.mikrotik.com/viewtopic.php?f=7&t=56056&p=297081&hilit=3x3#p286346
