The Major PCQ Groups
The below link suggest that there are three major PCQ groups - but it doesn’t really explain what any of them do.
I’ve tried Googling but I’m not having much luck and I thought that perhaps somebody could shed some light on this for me.
Three Major PCQ Groups:
  • Equal bandwidth for a number of users
  • Certain bandwidth equal distribution between users
  • Unknown bandwidth equal distribution between users.
Link:
https://wiki.mikrotik.com/wiki/Manual:Queues_-_PCQ_Examples
Could you please explain a scenario where each of these could be applied and what the differences are?
Thanks!
Have you found the answer? I’m looking at this too.
In PCQ Examples there’s a legend saying
Note: More information about certain and unknown Distribution between routers can be found in PCQ manual.
But on the PCQ manual there’s no mention to those scenarios
ISPs for example, at a given time they could have their links almost free, but they offer different plans(For instance 25$ for 20Mbps, 40$ For 40Mbps, etc.. also could include sharing levels). Therefore, ISPs want to control their traffic by groups. Assigning a certain limit for each group.
Where all the users will get the same amount of bandwidth, It’s like the previous example, where only one group exist.
I can’t give you a real scenario, because, in order to Mikrotik work properly, it’s suggested to establish the the limit-at and/or max-limit
See: PCQ Rate Examples
Here it is possible to see what happens if PCQ-rate is, or isn’t specified. I must noted that if both limits (pcq-rate and max-limit) are unspecified, queue behavior can be imprecise. So it is strongly suggested to have at least one of these options set
I hope this helps you.
Additionally, I think that the terminology used in https://wiki.mikrotik.com/wiki/Manual:Queues_-_PCQ_Examples is not formal nor a standard (Maybe I’m wrong).
