The map is not saved
Good day. I have mikrotik rb750Gr3, installed the dude. After that, I create a network map in the client, everything works fine, but after restarting the mikrotik, the map disappears. How to solve this problem.
Hello, John39!
Probably you may find some information in the following forum topic: The dude reset configuration [SOLVED]
Thank you!
Many thanks, I forgot to specify the path to the database on micro SD. The question is settled.
