the most stable solution for ptp link less then 7Km?
Hi
I want connect 2 network 7Km away.
The link must be very stable.
data type is all type off data(video, voice, db query, and etc) so maybe many Packet will transfer per second.
rate maybe 50Mbps.
nois is medium(not low and not very high)
wich the best solution?
is this solution as stable for my scenario?
RB411AH+ubntSR71-15+flat panel 23dbi dual?
QRT 5 should be adequate for your task.
now i have sextant. its very unstable(must restart evry 3-4 days). I read in other forum that qrt too(very unstable)
If the device restarts, you should check the log to see why. Or email supout.rif file to support. Usually there is clear reason for any restart, and hardware is very rarely the cause.
QRT 5 has been very stable in my network. It neither restart nor freeze.
i restart it manually, because it not work.
This description is very unclear. What didn’t work? Were you able to connect to it? Did it have any flashing lights? Please make a supout.rif file before the reboot, or after
som time winbox cant find it. i cant ping it. led pow and and link is on, but it hang up and when im tray to connect it with mac address it says wrong password!
some time i must open it and reset with reset button.
this problems are not for one sextant, some sextant in my network have these problems
even now i reset one of them with reset button, but says wrong password!!!
these files is supout of my sxt that today say wrong password and i reset it with reset button
