The problem of using netwatch
Im trying to make a failover script. But the problem of using netwatch, host would still be available on the other interface. Can we make a netwatch that would only test connectivity on a specific interface.
Netwatch is useless for failover scripts. Its also useless if I use the check-gateway using routes because gateway or remote peer is active, except that the gateway doesn’t have internet connectivity anymore.
set a static route for the host you are watching, use different hosts for the different interfaces
