The problem with CCR1036-12G-4S
EN
I do not speak English , I use a translator , I'll be brief .
My entire network as a provider , built on Mikrotik, was great hope that this will continue indefinitely, with the advent of more powerful devices will jump on them and only work Mikrotik. But after the growth of the subscriber base to 500 users and up to today , they have 1000 - problems grow with each passing day ... That and the fact that after the firmware 6.5 - no new without problems does not work ...
The main problem I have - it is the loss of Interfaces in Winbox - Vlan as well as physical - they are lost somewhere - the color assigned to the IP- address this interface also flies ... but when a large quantity of - you know - how many problems it can cause . ..
Another problem - the problem with speed subscribers . Authorization is based on PPPoE, subscriber rate allocated to Example 5 mb, he also gets it in the best case 2-3 mb. This despite the fact that the outer channel is free on 30 percent . It started as I wrote at the beginning - after increasing subscriber base of more than 500 people.
I have long been looking for answers to these questions - because of the language barrier did not write here , and for about two months looking honestly not that wanting alternative Mikrotik, knowing how easy RouterOS - but the quality of the service provided - if I do not fix , you 'll lose subscribers ...
Very ask you , administration and technical support Mikrotik, help find the cause, if the problem RouterOS - correct it ... If the technical support costs money - call it , I'll pay ... Do not leave me this message without attention ...
And thank you in advance !
RU
Проблема с CCR1036-12G-4S
Я не говорю по английски,пользуюсь переводчиком,буду краток.
Моя вся сеть,как провайдера,построена на Mikrotik, была большая надежда на то что так будет продолжаться бесконечно,с появлением более мощных устройств,буду переходить на них и работать только Mikrotik. Но после роста абонентской базы до 500 абонентов и до сегодня, их уже 1000 - проблемы разрастаются с каждым днём... Это и то что после прошивки 6.5 - ни одна новая без проблем не работает...
Основная проблема у меня - это потери нтерфейсов в Winbox - как Vlan так и физических - они куда-то теряются - настройки как присвоенные IP-адреса этим интерфейса тоже слетают... а при большом количестве - сами понимаете - сколько проблем это может вызвать...
Ещё одна проблема - проблема со скоростью абонентам. Авторизация построена на PPPoE, абоненту выделяется скорость к примеру 5 мб, он же её получает в лучшем случае 2-3 мб. Это при том что внешний канал свободен на процентов 30. Это началось как я уже писал в начале - после увеличения абонентской базы более 500 человек.
Я давно уже ищу ответы на эти вопросы - из-за языкового барьера, не писал сюда, и уже около двух месяцев ищу, честно говоря не очень того желая, альтернативу Mikrotik, зная насколько удобна RouterOS - но, качество предоставляемой услуги - если я не исправлю, то останусь без абонентов...
Очень Вас прошу, администрацию и техподдержку Mikrotik, помогите найти причину, если проблема в RouterOS - исправьте её... Если эта техподдержка стоит денег - назовите, я оплачу... Не оставляйте моё это сообщение без внимания...
Заранее благодарствую!
