Here, some of the radiation pattern of antennas Mikrotik (Omnitik 5, QRT-5AC, SextantG, SXT Lite 5, SXT SA 5).
You can download it from:
https://yadi.sk/d/uj3UkKzF38R7DJ
We already provide ANT files, which Radio Mobile can read. I guess you just converted the same? Which program uses this MSI format?
Hi Normis!
This files is result of precise and hard work. We digitized your graphical antennas pattern by some soft and then build MSI file format (based on UBNT template)
If possible check them. Maybe some wrong. All of this patterns not public found in ANT or MSI format.
This file is plain text format and easy convert to ANT format
just remember for zero point of ANT is on 90 degree of diagramm
Bitrek team
This is patterns for mANT30
https://yadi.sk/d/qbA00Qxf38U2am
Except mANT, also these:
https://routerboard.com/RBLHG-5nD
https://routerboard.com/RBSXTLTE3-7
https://routerboard.com/RBDisc-5nD
other new products will also have them
The radiation patterns for Mant19s shows this, is this correct?.
To Rmnalk
Hi! Strange pattern. Why dB scale only up to 20 dBi when gain is 30 dBi
Attached file show right pattern with firs and second side lobe
Maybe this pattern not Lg scale
mANT19 is an sector antenna with an opening of 120 degrees .
This radiation pattern is too narrow .
My mistake. Sorry. Wrong read about mant19
Hi, this file is downloaded from https://i.mt.lv/routerboard/files/160905105029pattern.ant and read with radiomobile version 11.6.5, Could someone do this procedure and post the result?.
Regards.
you have manually entered the gain as 20.
pattern shape will be the same, no matter the gain, the radio waves don’t stop ![]()
Antenna patterns at https://mikrotik.com/product/RBLHG-5nD:
160721104257pattern.ant
160721104238pattern.ant
When I put on radio mobile. It says that LHG has 99,9dbi gain antenna !!! : I set antenna gain =0 dbi in the configuration system and a I select antenna type= 160721104257pattern.ant
Does the same thing happen to someone else?
Wrong pattern?
Thanks in advance
Hello all!
Newbie question here.
where can I find radiation patterns of current mikrotik wireless SOHO devices, in just a graphic format? I mean, no need for a file, just for picking a correct device for my scenario. But on product pages I cant seem to find the radiation pattern.
I looked into brochures, don’t have it. Quick setup either. wAP ac for instance.
thanks!
x2
x3
LHG5 radiation pattern https://yadi.sk/d/1fzzjnJuqXnFBQ
P.S. in original ANT files main power level is up to 24dB - for correct use pattern data need to decrease on it
https://routerboard.com/RBDisc-5nDother new products will also have them
Hi.
Are “other new products” RBD22UGS-5HPacD2HnD-15S, RBLHGG-5HPacD2HPnD-XL and another devices, came after 2018-19-20 years?
I can not find .ant files for them in Support & Downloads tab.
Thank you.
