The right way to upgrade MT with wireless-test
what is the right /safe way how to upgrade a MT box which uses wireless-test package?
For test purposes I have upgraded about 20 RBs (RB133xx, RB411) with 3.22 to 3.23 and it worked fine (except one case - one RB didn;t booted properly). Then I upgraded 2 RB boxes (RB133C3 with 16MB RAM) from 3.20 to 3.23. Both boxes booted but there was no wireless package active. The wireless-3.23 was disabled and wireless-test-3.23 (which I uploaded together with main package) was no present. When a technician enabled the wireless-3.23 package and rebooted the box there was no wireless related config - i.e wlan1 interface was disabled and other wireless settings was reset.
In each case I uploaded the main .npk package and wireless-test package and then the box was rebooted.
So since there is no all-in-one package which contains wireless-test what is the correct way how to upgrade a box which is using wireless-test? Enable the regular wireless package->upgrade->reboot->install wireless-test=>reboot ?? The boxes are accessible only through the WiFi interface so the interface should be working in any step of the upgrade…
thanks
do not use ‘main’ package, use all needed separate packages
