The role of radio circuits small white patch
If that, check a lot of information, I did not find. SMD red box what role, her brother know that you answer the next.
This is used by factory only, it has no use for end user.
I want to know what the two white patches are, capacitors, inductors, resistors, or simply make the connection with it.
Hi.
I think, in the red squared area you can see the impedance matching circuit for the PCB antenne.
With your resistance probe, you can guess the type of the white items. Low resistance → inductor… very high resistance → capacitor. :slight_smile:
Regards: CsXen
