the same external ip in briddged mikrotik
im trying to configure bridge with the same external IP address for mikrotik and for the server behind mikrotik. Is such configuration possible? Added briddged interfaces:
/ interface
add name=“bridge1” mtu=1500 arp=enabled stp=no priority=32768 ageing-time=5m forward-delay=15s garbage-collection-interval=5s hello-time=2s max-message-age=20s comment=“” disabled=no
add interface=ether1 bridge=bridge1 priority=128 path-cost=10 comment=“” disabled=no
add interface=ether3 bridge=bridge1 priority=128 path-cost=10 comment=“” disabled=no
configured ip address on bridge1 interface:
/ ip address
add address=84.32.134.55/25 network=84.32.134.0 broadcast=84.32.134.127 interface=bridge1 comment=“” disabled=no
redirected winbox traffic destined for mikrotik port to localhost:
/ ip firewall nat
add chain=dstnat action=redirect to-ports=8291 dst-port=8291 protocol=tcp comment=“” disabled=no
it seems bridge works, but then can’t connect to mikrotik through winbox with 8291 port.
I feel that some mac rewriting is still needed to be able to connect to microtik through the same ip address. Is that a case? Or such config cant be done at all?
Antanas
