the soft-key is change
after format my diesk (64M pqi DOM), my soft-key was changed
my old key :m83d-icn (level 5)
the new key :k3b9-zrn
How to restore the key ?
Another problem is Each disk format this, always changing key
If you format the hd you will loose your key, and the soft-id will change too… You should read the documentation and the forums before… :unamused:
Regards
José Ignacio Acosta
Cibernet Comunicaciones / Mikronet
Joaquín V. González
Salta - Argentina
http://www.mikronet.com.ar
http://www.cibernetcom.com.ar
i has read the documentation
but the soft-key chang is a truth
now, I doubt that the so-called hardware encryption methods
if format HD WILL CHANG THE soft key
please make a warning on the first web
It’s on the faq’s, on the wiki and on the manual.
You must to read the faqs first.
Maxi
