The sync button doesn’t work on PWR-Line AP
Recently purchased a pair of PWR-Line APs and discovered the sync button refuses to sync two PWR-Line AP devices together.
Followed the instructions, cleared all PLC settings, then used the hold for 2 seconds to start the sync process, and nothing. The two devices do not find each other and the keys are different. Verified by checking with a laptop and cable individually in winbox.
If I use the join button in winbox, it works fine. But this feature (join with a button) should work.
On the same circuit, no power strips or filters in between. Odd that the join button in winbox works, but not the dedicated sync button. The lights flash as expected… but the devices never find each other.
updated RouterOS and firmware, still same issue.
Any suggestions?
