The Wi-Fi connection is delayed and works so slowly sometimes.
Please review and assist me with the following issues. We are a school with many laptops and iPads, but our Wi-Fi connection is causing significant problems. For some reason (I suspect an issue with the Wi-Fi configuration), the connection frequently drops. At times, it doesn’t work for 5-10 seconds, and other times it displays “connecting” and repeatedly attempts to establish a connection.
Below is our current Wi-Fi configuration for your reference:
anynameyouwish.txt (5.52 KB)
The frequent connection drops of ~ 5-10 Seconds cound be related with allow-signal-out-of-range=10s
You already made some access-list entries, most likely to mitigate devices connecting to a week signal.
But i don`t think it*s quite right…
I found some other Forum Post with some recommendations
http://forum.mikrotik.com/t/stop-weak-signal-neighor-attempting-to-connect/146543/7
http://forum.mikrotik.com/t/limit-clients-by-signal-range/167088/13
If the Issues persist,
Use “/system logging topics=wireless” to see connection attempts, accepts, and rejects in the log.
