There is any way to put 30v on rb450g ?
Dears,
There is any way to bypass the overprotection on RB 450G to use 30v or 29v DC ?
I Know the risk to burn but 28v cause problems on DC solar 24v stations.
Regards,
Ademir Peixoto
hi
you can use the UA7824 CI … it will provide up to 1.5 A and 27V< Vin < 38V
good luck
Or add 4-5 pcs 1A diodes in serial in that way you get few volts drop on diodes circuit.
