There is no signal!!!???
Hi!
Well… My MikroTik works on a PIII 500mhz 128 mbram, and once a day signal from ap disapears and when I hard reset machine it comes back again what is the problem… is it hard disk, is it wifi card, or saomething else. wifi card is gigabyte ath5213…
Hmm, can you login to this machine when it looses signal? If so, then your PC hardware is OK, then there is just a problem with wifi card. Try to set logs to disk and then after failure and restart check out the logs. This is very likely to be wifi card or software related problem because of this card. What version of Mikrotik do you use?
Hi
well I didnt set up logs or I dont know how because log file I see is just for the session that is “active” well I dont know if I can log on :slight_smile: im at work in Novi Sad :slight_smile: and MT 2.9 is at titel…
