There is not Ethernet, Wireless [Kind of Physical interface]
Hi
Mikrotkit Team and Users
I am just a begginer here with this great tools
i already get an copy of Mikrotkit OS 6.36
and i have a little problem, that dont allow me to forward next step
to config it out:
There`s the message:
When i type in command line to config it out with the following command > setup
then i type my choice a
to config ip address and gateway.
its says:
There is not ethernet, wireless or another kind of physical interface.
if this router has interface card that is not automatically detected, you need to load an appropiate driver first.
this is my problem
used PC DELL OPTIPLEX 380 WITK PXE ENABLED IN BIOS
i install in PC to bring it as router, but if this problem persist i cant continue.
please help me.
i test in VMWARE and work great, but remember virtualization is not the same way as physical
Thanks a lot
if yours need more info, please tell me!!
It just means that you have no LAN cards which are recognizable by x86 ROS version.
So what can i do?
Use VMWare as host or add proper LAN cards.
