hi all ,
i saw strange ips in hosts not in my server range.
my server range is : 192.168.88.11-192.168.88.254
strange ips : 110.xx.xx.xx
is that normal or not normal , and what is the solve ?
hi all ,
Look and see what interface those addresses are on - I assume you’re talking about the IP>ARP list. If so, and these strange hosts are on your Wan interface, then this is most likely just your neighbors and it’s normal, but if you’re talking about hotspot hosts, then possibly a user has connected with a static IP address on their equipment - Hotspot works with these hosts as well. Otherwise, you may have a rogue DHCP server in your network somewhere.
yes i am talking about hotspot hosts. so it is normal .
thanks for help dear
