Equis
August 18, 2006, 11:53pm
1
You get better up times with only 1 minipci card in board
CM9s work better than Prisim when many cards on one tower
Prisim will handle outside interference better (seem sliek a contridiction of 2 but its true)
SR2’s are ok but best when they are the only card on the tower.
RB500 with 3 cards gettes better link uptimes with a 18v 1amp PSU then a 12V1.5amp PSU
If your using OSPF put your wlans in bridge (by themselves) wlan will dissaper but bridge will stay, gives better reliability
default TX power works best
Frenal zone os overrated, I have a 40km link on a 1 meter pole.
RouterOS is better than all 4 other platforms I’ve used, I started with RouterOS, went away, came back.
Dont buy cheap crap, a $100 CPE will cost more than a $300CPE over 3 years
Queue here to flame ---->>>>
Just thought I’d post perhaps it may help someone.
sten
August 20, 2006, 12:47am
2
Equis:
disable-running-check=yes
Equis:
Oh sure, physics in general is completely overrated
Equis:
Amen
bjohns
August 20, 2006, 3:03am
4
I think he’s saying that the negative effects of not having >%60 freznal zone are exagerated. Probably a greater issue for radio systems that don’t have all the tolerance handling features of the modern wifi system.
Equis:
For sure. I like to try and use the highest voltage I can.
Equis
August 20, 2006, 3:06am
5
does that fix the OSPF Problem?
bjohns
August 20, 2006, 3:13am
6
Yer, it leaves the interface ‘up’ when there’s nothing associated.
Equis wrote:
5. RB500 with 3 cards gettes better link uptimes with a 18v 1amp PSU then a 12V1.5amp PSU
yes, better, better and better.
Peace all
BalimoreDOTcom
pacman
August 20, 2006, 9:45am
9
Mind you, he did not say what the 1m pole was attached to
Equis
August 20, 2006, 9:54am
10
Yea, its attached to a 70 meter tower..
Nah, its just on a single story house
