Please see or tell me what I am doing wrong. All I need is this script to turn off an ethernet3 port and then later turn it on. But my silly script is not working.
I am not using {} is that the problem? Tried different things I can not get it to work please assist. Thanks!
/interface ethernet set ether3\
disable =no
Or should it be
/interface ethernet set ether3 disable =no
Any advice.
Also does the script need different things if it is being executed via the scheduler such as braces or not?
Awesome so this is the script I got to go and it works! What it does is reconnects and emails me if a certain backhaul gets what I call a dry sock connection. The connection stays linked but nothing passes. It happens during extreme snow conditions out here. Not sure if it is a static case or what but nonetheless here is my code that I use to fix this problem.
The script will turn off wlan2 for 5 seconds and then turn it back on which will cause everything to re-sync and work again. This code is now something that I deploy to all backhauls to keep everything running and to help me get more sleep.
