Throttling a connection between certail hours
How would I go about throttling an Interface connection between certain hours? Or for certail protocols between certain hours?
GO to the wikie scripting area. You can find it above under FAQ and examples. Go there and go under scripting and you will find a script that will do what you want. Good luck/. -Jordan
Thanks Jordan, will go have a look
