I’m building a backhaul which i’d like to be able to handle 100-150 mbps throughput peaks.
It’s in an OSPF network running MPLS.
i’ll be using the link bonding (round robin) to put together 3 wireless links between the towers.
i don’t have much experience with high throughput applications and i want to be sure i get the right routers.
i’m considering the RB2011, but it reads pretty light on horsepower even compared to a RB450g.
would it do the trick or would i need to step it up to a 1100ah?
i’ve looked at the throughput ratings on the spec sheet and i’m not sure i’m reading them right.
is “frame size” just MTU? if so even the RB750 should pass over 400mbps.. but on the bench i don’t get that with a pair of 750s, so whats am i doing wrong?
any input is appreciated, thanks
