sebastia: Thank you for the reply. The MikroTik at both locations where we are having this challenge is being used as a simple WAP. It’s not being used for any higher function. It’s plugged into a network jack in one office area going back to a non-managed switch. All DHCP etc. are handled by the gateway device. On the issue of the link, yes, I was just referring to the link data. I just wanted to make sure that I made it clear that I had verified that we weren’t in a 100 Mbps environment that could contaminate our test results. Tests have been run via an online speed test, iPerf across the network, and to get the cleanest test possible, we even hooked the MikroTik to a single laptop via cable, and then ran an iPerf wirelessly from one laptop to the other. All tests were consistent and maxed out at about 150 Mbps.
mkx: Thank you for offering to help with this. Here is the output you requested. I redacted the usernames and MAC addresses from the access list. I hope that’s okay.
[admin@TCG-MikroTik] > /interface traffic-eng erface wireles export verbose hide-s
ensitive
bad command name erface (line 1 column 24)
[admin@TCG-MikroTik] >> /interface wireless export verbose hide-sensitive
# jul/03/2019 10:04:37 by RouterOS 6.44.3
# software id = 1F0I-1CJV
# model = RouterBOARD wAP G-5HacT2HnD
# serial number = A63309D607BC
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk disable-pmkid=no \
eap-methods=passthrough group-ciphers=aes-ccm group-key-update=5m \
interim-update=0s management-protection=disabled mode=dynamic-keys \
mschapv2-username="" name=default radius-called-format=mac:ssid \
radius-eap-accounting=yes radius-mac-accounting=yes \
radius-mac-authentication=yes radius-mac-caching=disabled \
radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username \
static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=none \
static-sta-private-algo=none static-transmit-key=key-0 supplicant-identity=\
MikroTik tls-certificate=none tls-mode=no-certificates unicast-ciphers=\
aes-ccm
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=none allow-sharedkey=no \
ampdu-priorities=0 amsdu-limit=8192 amsdu-threshold=8192 antenna-gain=2 \
area="" arp=enabled arp-timeout=auto band=2ghz-b/g/n basic-rates-a/g=6Mbps \
basic-rates-b=1Mbps bridge-mode=enabled channel-width=20/40mhz-XX \
compression=no country="united states3" default-ap-tx-limit=0 \
default-authentication=yes default-client-tx-limit=0 default-forwarding=yes \
disable-running-check=no disabled=no disconnect-timeout=3s distance=indoors \
frame-lifetime=0 frequency=auto frequency-mode=regulatory-domain \
frequency-offset=0 guard-interval=any hide-ssid=no ht-basic-mcs=\
mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-supported-mcs="mcs-0,mcs-\
1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-1\
3,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23" \
hw-fragmentation-threshold=disabled hw-protection-mode=none \
hw-protection-threshold=0 hw-retries=7 installation=any \
interworking-profile=disabled keepalive-frames=enabled l2mtu=1600 \
mac-address=B8:69:F4:73:CC:05 max-station-count=2007 mode=ap-bridge mtu=\
1500 multicast-buffering=enabled multicast-helper=default name=wlan1 \
noise-floor-threshold=default nv2-cell-radius=30 nv2-downlink-ratio=50 \
nv2-mode=dynamic-downlink nv2-noise-floor-offset=default nv2-qos=default \
nv2-queue-count=2 nv2-security=disabled nv2-sync-secret="" \
on-fail-retry-time=100ms preamble-mode=both radio-name=B869F473CC05 \
rate-selection=advanced rate-set=default rx-chains=0,1 scan-list=default \
secondary-channel="" security-profile=default ssid=TCG-2GHz \
station-bridge-clone-mac=00:00:00:00:00:00 station-roaming=enabled \
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps \
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps tdma-period-size=2 tx-chains=\
0,1 tx-power-mode=default update-stats-interval=disabled vlan-id=1 \
vlan-mode=no-tag wds-cost-range=50-150 wds-default-bridge=none \
wds-default-cost=100 wds-ignore-ssid=no wds-mode=disabled \
wireless-protocol=802.11 wmm-support=disabled wps-mode=push-button
set [ find default-name=wlan2 ] adaptive-noise-immunity=none allow-sharedkey=no \
area="" arp=enabled arp-timeout=auto band=5ghz-a/n/ac basic-rates-a/g=6Mbps \
bridge-mode=enabled channel-width=20/40/80mhz-Ceee compression=no country=\
"united states3" default-ap-tx-limit=0 default-authentication=no \
default-client-tx-limit=0 default-forwarding=yes disable-running-check=no \
disabled=no disconnect-timeout=3s distance=indoors frame-lifetime=0 \
frequency=auto frequency-mode=regulatory-domain frequency-offset=0 \
hw-protection-threshold=0 hw-retries=7 installation=indoor \
mac-address=B8:69:F4:73:CC:04 max-station-count=2007 mode=ap-bridge mtu=\
1500 multicast-buffering=enabled multicast-helper=default name=wlan2 \
nv2-cell-radius=30 nv2-downlink-ratio=50 nv2-mode=dynamic-downlink nv2-qos=\
default nv2-queue-count=2 nv2-security=disabled nv2-sync-secret="" \
on-fail-retry-time=100ms preamble-mode=both radio-name=B869F473CC04 \
rate-selection=advanced rate-set=default rx-chains=0,1,2 scan-list=default \
secondary-channel="" security-profile=default ssid=TCG-5GHz \
tdma-period-size=2 tx-chains=0,1,2 tx-power-mode=default \
update-stats-interval=disabled vht-basic-mcs=mcs0-7 vht-supported-mcs=\
mcs0-9,mcs0-9,mcs0-9 vlan-id=1 vlan-mode=no-tag wds-cost-range=50-150 \
wds-default-bridge=none wds-default-cost=100 wds-ignore-ssid=no wds-mode=\
disabled wireless-protocol=802.11 wmm-support=disabled wps-mode=push-button
/interface wireless manual-tx-power-table
set wlan1 manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbp\
s:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17,HT20-0:17,H\
T20-1:17,HT20-2:17,HT20-3:17,HT20-4:17,HT20-5:17,HT20-6:17,HT20-7:17,HT40-0:\
17,HT40-1:17,HT40-2:17,HT40-3:17,HT40-4:17,HT40-5:17,HT40-6:17,HT40-7:17"
set wlan2 manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbp\
/interface wireless nstreme
set wlan1 disable-csma=no enable-nstreme=no enable-polling=yes framer-limit=\
3200 framer-policy=none
set wlan2 disable-csma=no enable-nstreme=no enable-polling=yes framer-limit=\
/interface wireless access-list
add allow-signal-out-of-range=10s ap-tx-limit=0 authentication=yes \
client-tx-limit=0 comment="REDACTED" disabled=no forwarding=yes \
interface=any mac-address=REDACTED private-algo=none signal-range=\
-120..120 !time vlan-id=1 vlan-mode=no-tag
client-tx-limit=0 comment="REDACTED" disabled=no \
forwarding=yes interface=any mac-address=REDACTED private-algo=\
none signal-range=-120..120 !time vlan-id=1 vlan-mode=no-tag
client-tx-limit=0 comment=REDACTED disabled=no forwarding=yes interface=\
any mac-address=REDACTED private-algo=none signal-range=-120..120 \
client-tx-limit=0 comment=\
client-tx-limit=0 comment="REDACTED" disabled=no forwarding=\
yes interface=any mac-address=REDACTED private-algo=none \
client-tx-limit=0 comment=Roku disabled=no forwarding=yes interface=any \
mac-address=00:0D:4B:40:68:47 private-algo=none signal-range=-120..120 \
client-tx-limit=0 comment=REDACTED disabled=no forwarding=yes interface=any \
client-tx-limit=0 comment="REDACTED" \
disabled=no forwarding=yes interface=any mac-address=REDACTED \
private-algo=none signal-range=-120..120 !time vlan-id=1 vlan-mode=no-tag
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=\
00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300 \
frames-per-second=25 receive-all=no ssid-all=no
/interface wireless cap
set bridge=none caps-man-addresses="" caps-man-certificate-common-names="" \
caps-man-names="" certificate=none discovery-interfaces="" enabled=no \
interfaces="" lock-to-caps-man=no static-virtual=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name="" memory-limit=10 \
multiple-channels=no only-headers=no receive-errors=no streaming-enabled=no \
streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
