Hello that such
I would like to help me with a configuration I explain what I do.
I have a caching server which is the THUNDERCACHE, I want to run with a mikrotik doing PARENT PROXY, so far the comments if I could do, the question is that the quality mikrotik doing QUEUE TREE service, which limits correctly users the problem is that when a customer sees a video is saved in the THUNDERCACHE perfectly fine, but when you want to see the video does not load quickly “because if that is stored should” because it does mikrotik watch the video with the limitation that I have in the queue. My question is there a way to play videos instantly without the mikrotik the limit.
Thanks.
