Ticket not being responded to
I’ve had a ticket open for 2 weeks now, without a response. MikroTik used to respond to tickets within a couple of days or less. Has something changed? I see there was a post in the forums from someone else a couple of weeks ago about the exact same problem.
My ticket number is SUP-171452
I have 21 access points exhibiting this problem.
I’m seriously beginning to question whether I should have deployed using CAPSMAN v2, and whether I should have paid the extra for the cap ax over the cap XL ac.
This is user forum, do not post only ticket number, for us is useless, describe also the problem…
Since Upgrading to CAPSMAN v2 with cAP ax from CAPSMAN v1 with wAP ac, I’ve been getting WiFi devices connected at 0/0 bps TX/RX rates
You’ll see I have a lot of devices with a 1Mbps TX as well (1000Kbps TX). That’s concerning as well, but the 0/0 is my main complaint.
I have 2.4GHz and 5GHz separated out into two separate SSID’s as I’ve had issues in the past with certain devices not able to connect to wifi when I have a blended SSID.
On CAPSMAN v1, there was the ability to select which speeds were able to be negotiated upon connection to the wifi network. CAPSMAN v2 does not seem to have this ability.
I’ve seen reports of iPhone 13 having issues on the forums. I’ve talked to a lot of the end users having problems, and only a small percentage of them (maybe only one) has an iPhone 13.
I attached a supout.rif file to the ticket as well. Obviously that’s not going to get attached here as it exposes too much information.
Could you please share your config, at least the wifi part?
/interface wifi export
Remove serial and any other provate info.
With this config we can provide you with some tips and tricks.
Weeks or months between responses to tickets has been my experience.
If not interested in forum help, there is always → https://mikrotik.com/consultants
I will look into why your ticket was not answered until now, but I can already see that this is not a bug report, but requires debugging of a running network. MikroTik does not offer such services for free, we have consultants that you can hire (above post has a link). The MikroTik support system is for rerporting bugs and asking specific questions.
Hello Normis,
I received a response. It’s apparently a feature of the existing firmware. They will be adding in a fix to the firmware to hide those in the future to avoid any confusion.
I already work with Hani Rahrouh (listed on the consultants list) and had already consulted with his company; they were unable to determine what the issue was. That is why I submitted a ticket.
Please see the export below. Did you want a dump of any of the wifi interfaces on any of the cAP ax's? I have several different transmission strengths configured to lessen rx/tx errors. Basement and 2nd floor are separated by a middle floor. Neighboring houses are separate by at a minimum a fire separation wall, and in others an outside air gap of up to 5 meters. All houses save for 37 area are duplexes, so 21 and 25 would be two halves of one duplex. 37 is a single family house.
2024-12-01 12:54:03 by RouterOS 7.16.1
model = CCR2004-16G-2S+
/interface wifi channel
add band=2ghz-g disabled=no frequency=2412 name=ch1 width=20mhz
add band=2ghz-g disabled=no frequency=2437 name=ch6 width=20mhz
add band=2ghz-g disabled=no frequency=2462 name=ch11 width=20mhz
add band=5ghz-ax disabled=no frequency=5160 name=ch36 width=20mhz
add band=5ghz-ax disabled=no frequency=5200 name=ch40 width=20mhz
add band=5ghz-ax disabled=no frequency=5220 name=ch44 width=20mhz
add band=2ghz-ax disabled=no name=ch24ghz width=20mhz
add band=5ghz-ax disabled=no name=ch5ghz width=20mhz
/interface wifi datapath
add bridge=BridgeStudent disabled=no name=dp1
/interface wifi security
add authentication-types=wpa2-psk disabled=no name=secfg
/interface wifi configuration
add country=Canada datapath=dp1 disabled=no mode=ap name=cfg-24 security=secfg ssid=DSR
add country=Canada datapath=dp1 disabled=no mode=ap name=cfg-5 security=secfg ssid="DSR 5G"
add country=Canada datapath=dp1 disabled=no mode=ap name=cfg5-15dBi security=secfg ssid="DSR 5G" tx-power=15
add country=Canada datapath=dp1 disabled=no mode=ap name=cfg5-13dBi security=secfg ssid="DSR 5G" tx-power=13
add country=Canada datapath=dp1 disabled=no mode=ap name=cfg5-17dBi security=secfg ssid="DSR 5G" tx-power=17
/interface wifi capsman
set enabled=yes interfaces=BridgeStudent package-path=/ap-firmware require-peer-certificate=no upgrade-policy=none
/interface wifi provisioning
add action=create-dynamic-enabled comment="House 37" disabled=no master-configuration=cfg5-15dBi name-format=%I-%R radio-mac=48:A9:8A:C2:76:26 supported-bands=5ghz-ax,5ghz-ac
add action=create-dynamic-enabled comment="House 37" disabled=no master-configuration=cfg-24 name-format=%I-%R radio-mac=48:A9:8A:C2:76:27 supported-bands=2ghz-ax,2ghz-g
add action=create-dynamic-enabled comment="House 39 Basement" disabled=no master-configuration=cfg5-15dBi name-format=%I-%R radio-mac=48:A9:8A:C2:72:BA supported-bands=5ghz-ax,5ghz-ac
add action=create-dynamic-enabled comment="House 39 Basement" disabled=no master-configuration=cfg-24 name-format=%I-%R radio-mac=48:A9:8A:C2:72:BB supported-bands=2ghz-ax,2ghz-g
add action=create-dynamic-enabled comment="House 47 Basement" disabled=no master-configuration=cfg5-15dBi name-format=%I-%R radio-mac=48:A9:8A:C2:77:F2 supported-bands=5ghz-ax,5ghz-ac
add action=create-dynamic-enabled comment="House 47 2nd Floor" disabled=no master-configuration=cfg5-15dBi name-format=%I-%R radio-mac=F4:1E:57:12:91:7B supported-bands=5ghz-ax,5ghz-ac
add action=create-dynamic-enabled comment="House 47 Basement" disabled=no master-configuration=cfg-24 name-format=%I-%R radio-mac=48:A9:8A:C2:77:F3 supported-bands=2ghz-ax,2ghz-g
add action=create-dynamic-enabled comment="House 47 2nd Floor" disabled=no master-configuration=cfg-24 name-format=%I-%R radio-mac=F4:1E:57:12:91:7C supported-bands=2ghz-ax,2ghz-g
add action=create-dynamic-enabled comment="House 21 Basement" disabled=no master-configuration=cfg5-15dBi name-format=%I-%R radio-mac=F4:1E:57:12:91:E1 supported-bands=5ghz-ax,5ghz-ac
add action=create-dynamic-enabled comment="House 21 Basement" disabled=no master-configuration=cfg-24 name-format=%I-%R radio-mac=F4:1E:57:12:91:E2 supported-bands=2ghz-ax,2ghz-g
add action=create-dynamic-enabled comment="House 25 Basement" disabled=no master-configuration=cfg5-13dBi name-format=%I-%R radio-mac=F4:1E:57:12:91:DD supported-bands=5ghz-ax,5ghz-ac
add action=create-dynamic-enabled comment="House 25 Basement" disabled=no master-configuration=cfg-24 name-format=%I-%R radio-mac=F4:1E:57:12:91:DE supported-bands=2ghz-ax,2ghz-g
add action=create-dynamic-enabled comment="House 25 2nd Floor" disabled=no master-configuration=cfg5-15dBi name-format=%I-%R radio-mac=F4:1E:57:12:91:55 supported-bands=5ghz-ax,5ghz-ac
add action=create-dynamic-enabled comment="House 25 2nd Floor" disabled=no master-configuration=cfg-24 name-format=%I-%R radio-mac=F4:1E:57:12:91:56 supported-bands=2ghz-ax,2ghz-g
add action=create-dynamic-enabled comment="House 21 2nd Floor" disabled=no master-configuration=cfg5-17dBi name-format=%I-%R radio-mac=F4:1E:57:12:90:6F supported-bands=5ghz-ax,5ghz-ac
add action=create-dynamic-enabled comment="House 21 2nd Floor" disabled=no master-configuration=cfg-24 name-format=%I-%R radio-mac=F4:1E:57:12:90:70 supported-bands=2ghz-ax,2ghz-g
add action=create-dynamic-enabled comment="House 35 Basement" disabled=no master-configuration=cfg5-17dBi name-format=%I-%R radio-mac=F4:1E:57:12:91:D5 supported-bands=5ghz-ax,5ghz-ac
add action=create-dynamic-enabled comment="House 35 Basement" disabled=no master-configuration=cfg-24 name-format=%I-%R radio-mac=F4:1E:57:12:91:D6 supported-bands=2ghz-ax,2ghz-g
add action=create-dynamic-enabled comment="House 35 2nd Floor" disabled=no master-configuration=cfg5-13dBi name-format=%I-%R radio-mac=F4:1E:57:12:90:FB supported-bands=5ghz-ax,5ghz-ac
add action=create-dynamic-enabled comment="House 35 2nd Floor" disabled=no master-configuration=cfg-24 name-format=%I-%R radio-mac=F4:1E:57:12:90:FC supported-bands=2ghz-ax,2ghz-g
add action=create-dynamic-enabled comment="House 33 Basement" disabled=no master-configuration=cfg5-13dBi name-format=%I-%R radio-mac=F4:1E:57:12:90:ED supported-bands=5ghz-ax,5ghz-ac
add action=create-dynamic-enabled comment="House 33 Basement" disabled=no master-configuration=cfg-24 name-format=%I-%R radio-mac=F4:1E:57:12:90:EE supported-bands=2ghz-ax,2ghz-g
add action=create-dynamic-enabled comment="House 33 2nd Floor" disabled=no master-configuration=cfg5-15dBi name-format=%I-%R radio-mac=F4:1E:57:12:90:D7 supported-bands=5ghz-ax,5ghz-ac
add action=create-dynamic-enabled comment="House 33 2nd Floor" disabled=no master-configuration=cfg-24 name-format=%I-%R radio-mac=F4:1E:57:12:90:D8 supported-bands=2ghz-ax,2ghz-g
add action=create-dynamic-enabled comment="House 39 2nd Floor" disabled=no master-configuration=cfg5-15dBi name-format=%I-%R radio-mac=F4:1E:57:12:92:39 supported-bands=5ghz-ax,5ghz-ac
add action=create-dynamic-enabled comment="House 39 2nd Floor" disabled=no master-configuration=cfg-24 name-format=%I-%R radio-mac=F4:1E:57:12:92:3A supported-bands=2ghz-ax,2ghz-g
add action=create-dynamic-enabled comment="House 41 Basement" disabled=no master-configuration=cfg5-17dBi name-format=%I-%R radio-mac=F4:1E:57:12:92:4B supported-bands=5ghz-ax,5ghz-ac
add action=create-dynamic-enabled comment="House 41 Basement" disabled=no master-configuration=cfg-24 name-format=%I-%R radio-mac=F4:1E:57:12:92:4C supported-bands=2ghz-ax,2ghz-g
add action=create-dynamic-enabled comment="House 41 2nd Floor" disabled=no master-configuration=cfg5-15dBi name-format=%I-%R radio-mac=F4:1E:57:12:91:C5 supported-bands=5ghz-ax,5ghz-ac
add action=create-dynamic-enabled comment="House 41 2nd Floor" disabled=no master-configuration=cfg-24 name-format=%I-%R radio-mac=F4:1E:57:12:91:C6 supported-bands=2ghz-ax,2ghz-g
add action=create-dynamic-enabled comment="House 49 Basement" disabled=no master-configuration=cfg5-15dBi name-format=%I-%R radio-mac=F4:1E:57:12:91:87 supported-bands=5ghz-ax,5ghz-ac
add action=create-dynamic-enabled comment="House 49 Basement" disabled=no master-configuration=cfg-24 name-format=%I-%R radio-mac=F4:1E:57:12:91:88 supported-bands=2ghz-ax,2ghz-g
add action=create-dynamic-enabled comment="House 49 2nd Floor" disabled=no master-configuration=cfg5-13dBi name-format=%I-%R radio-mac=F4:1E:57:12:91:65 supported-bands=5ghz-ax,5ghz-ac
add action=create-dynamic-enabled comment="House 49 2nd Floor" disabled=no master-configuration=cfg-24 name-format=%I-%R radio-mac=F4:1E:57:12:91:66 supported-bands=2ghz-ax,2ghz-g
add action=create-dynamic-enabled comment="House 51 Basement" disabled=no master-configuration=cfg5-17dBi name-format=%I-%R radio-mac=F4:1E:57:12:91:45 supported-bands=5ghz-ax,5ghz-ac
add action=create-dynamic-enabled comment="House 51 Basement" disabled=no master-configuration=cfg-24 name-format=%I-%R radio-mac=F4:1E:57:12:91:46 supported-bands=2ghz-ax,2ghz-g
add action=create-dynamic-enabled comment="House 51 2nd Floor" disabled=no master-configuration=cfg5-15dBi name-format=%I-%R radio-mac=F4:1E:57:12:91:7F supported-bands=5ghz-ax,5ghz-ac
add action=create-dynamic-enabled comment="House 51 2nd Floor" disabled=no master-configuration=cfg-24 name-format=%I-%R radio-mac=F4:1E:57:12:91:80 supported-bands=2ghz-ax,2ghz-g
add action=create-dynamic-enabled comment="House 53 Basement" disabled=no master-configuration=cfg5-17dBi name-format=%I-%R radio-mac=F4:1E:57:12:91:71 supported-bands=5ghz-ax,5ghz-ac
add action=create-dynamic-enabled comment="House 53 Basement" disabled=no master-configuration=cfg-24 name-format=%I-%R radio-mac=F4:1E:57:12:91:72 supported-bands=2ghz-ax,2ghz-g
add action=create-dynamic-enabled comment="House 53 2nd Floor" disabled=no master-configuration=cfg5-17dBi name-format=%I-%R radio-mac=F4:1E:57:12:91:83 supported-bands=5ghz-ax,5ghz-ac
add action=create-dynamic-enabled comment="House 53 2nd Floor" disabled=no master-configuration=cfg-24 name-format=%I-%R radio-mac=F4:1E:57:12:91:84 supported-bands=2ghz-ax,2ghz-g
And a dump of some stats on the access points from querying the access points directly (stats were reset about 20m ago):
House 21 2nd Floor (5GHz): rx-packets: 30352; tx-packets: 310099; rx-drop: 0; tx-drop: 0; tx-queue-drop: 0; rx-error: 8; tx-error: 34; rx-error-rate: 0.03%; tx-error-rate: 0.01%
House 21 Basement (5GHz): rx-packets: 28809; tx-packets: 187294; rx-drop: 0; tx-drop: 0; tx-queue-drop: 0; rx-error: 177; tx-error: 727; rx-error-rate: 0.61%; tx-error-rate: 0.39%
House 25 2nd Floor (5GHz): rx-packets: 172005; tx-packets: 781900; rx-drop: 0; tx-drop: 0; tx-queue-drop: 0; rx-error: 1202; tx-error: 198; rx-error-rate: 0.70%; tx-error-rate: 0.03%
House 25 Basement (5GHz): rx-packets: 1292701; tx-packets: 2754606; rx-drop: 0; tx-drop: 0; tx-queue-drop: 0; rx-error: 2216; tx-error: 257; rx-error-rate: 0.17%; tx-error-rate: 0.01%
House 33 2nd Floor (5GHz): rx-packets: 1184685; tx-packets: 3172600; rx-drop: 0; tx-drop: 0; tx-queue-drop: 0; rx-error: 1523; tx-error: 58200; rx-error-rate: 0.13%; tx-error-rate: 1.83%
House 33 Basement (5GHz): rx-packets: 93476; tx-packets: 172440; rx-drop: 0; tx-drop: 0; tx-queue-drop: 0; rx-error: 253; tx-error: 0; rx-error-rate: 0.27%; tx-error-rate: 0.00%
House 35 2nd Floor (5GHz): rx-packets: 60602; tx-packets: 362389; rx-drop: 0; tx-drop: 0; tx-queue-drop: 0; rx-error: 1743; tx-error: 1039; rx-error-rate: 2.88%; tx-error-rate: 0.29%
House 35 Basement (5GHz): rx-packets: 133117; tx-packets: 838156; rx-drop: 0; tx-drop: 0; tx-queue-drop: 0; rx-error: 1572; tx-error: 289; rx-error-rate: 1.18%; tx-error-rate: 0.03%
House 39 2nd Floor (5GHz): rx-packets: 41602; tx-packets: 170790; rx-drop: 0; tx-drop: 0; tx-queue-drop: 0; rx-error: 409; tx-error: 1368; rx-error-rate: 0.98%; tx-error-rate: 0.80%
House 39 Basement (5GHz): rx-packets: 61950; tx-packets: 490004; rx-drop: 0; tx-drop: 0; tx-queue-drop: 0; rx-error: 27; tx-error: 25; rx-error-rate: 0.04%; tx-error-rate: 0.01%
House 41 2nd Floor (5GHz): rx-packets: 23396; tx-packets: 145971; rx-drop: 0; tx-drop: 0; tx-queue-drop: 0; rx-error: 14; tx-error: 1034; rx-error-rate: 0.06%; tx-error-rate: 0.71%
House 41 Basement (5GHz): rx-packets: 107252; tx-packets: 557423; rx-drop: 0; tx-drop: 0; tx-queue-drop: 0; rx-error: 4592; tx-error: 543; rx-error-rate: 4.28%; tx-error-rate: 0.10%
House 47 2nd Floor (5GHz): rx-packets: 160955; tx-packets: 992396; rx-drop: 0; tx-drop: 0; tx-queue-drop: 0; rx-error: 379; tx-error: 54; rx-error-rate: 0.24%; tx-error-rate: 0.01%
House 47 Basement (5GHz): rx-packets: 5371; tx-packets: 158941; rx-drop: 0; tx-drop: 0; tx-queue-drop: 0; rx-error: 325; tx-error: 48; rx-error-rate: 6.05%; tx-error-rate: 0.03%
House 49 2nd Floor (5GHz): rx-packets: 14743; tx-packets: 179510; rx-drop: 0; tx-drop: 0; tx-queue-drop: 0; rx-error: 12; tx-error: 8; rx-error-rate: 0.08%; tx-error-rate: 0.00%
House 49 Basement (5GHz): rx-packets: 10881; tx-packets: 166931; rx-drop: 0; tx-drop: 0; tx-queue-drop: 0; rx-error: 27; tx-error: 3; rx-error-rate: 0.25%; tx-error-rate: 0.00%
House 51 2nd Floor (5GHz): rx-packets: 441315; tx-packets: 1739451; rx-drop: 0; tx-drop: 0; tx-queue-drop: 0; rx-error: 354; tx-error: 5; rx-error-rate: 0.08%; tx-error-rate: 0.00%
House 51 Basement (5GHz): rx-packets: 49940; tx-packets: 310390; rx-drop: 0; tx-drop: 0; tx-queue-drop: 0; rx-error: 11; tx-error: 0; rx-error-rate: 0.02%; tx-error-rate: 0.00%
House 53 2nd Floor (5GHz): rx-packets: 510125; tx-packets: 1330333; rx-drop: 0; tx-drop: 0; tx-queue-drop: 0; rx-error: 22278; tx-error: 3973; rx-error-rate: 4.37%; tx-error-rate: 0.30%
House 53 Basement (5GHz): rx-packets: 17556; tx-packets: 184069; rx-drop: 0; tx-drop: 0; tx-queue-drop: 0; rx-error: 0; tx-error: 2; rx-error-rate: 0.00%; tx-error-rate: 0.00%
/interface wifi export for one of the CAPs (they have identical configs, but channel used will be different, depending on what capsman assigned to them):
2024-12-01 13:12:09 by RouterOS 7.16.1
model = cAPGi-5HaxD2HaxD
/interface wifi
managed by CAPsMAN
mode: AP, SSID: DSR 5G, channel: 5220/ax/eeCe
set [ find default-name=wifi1 ] configuration.manager=capsman datapath=capdp disabled=no
managed by CAPsMAN
mode: AP, SSID: DSR, channel: 2462/ax/eC
set [ find default-name=wifi2 ] configuration.manager=capsman datapath=capdp disabled=no
/interface wifi cap
set discovery-interfaces=bridgeLocal enabled=yes slaves-datapath=capdp
add bridge=bridgeLocal comment=defconf disabled=no name=capdp
