I have a couple of mikrotiks in my network that just stop responding, I go to the tower site and there are no lights on the ether ports and only 1 blue light on the side. If I power cycle it comes back and works fine, then later it will do it again. any ideas?
What series board? What version of the OS? Do you have them set to reboot at certain times of the day?
RB493AH 4.17 and no only have bulldog set
You will likely want to upgrade them to 5.x or downgrade to something before 4.15. At least 4.16 and 4.17 have a bug in them for the 400 series where if the board is told to reboot, it doesn’t shut down all the services right and hangs. It requires a physical reboot to fix.
I have the same problem the network interfaces stop responding for no reason. Version 5.7. RB435G
VERSION? FIRMWARE?
We have to wait for the report and action.
what routerboot version? What power adapter?
I tested 5.7 - 2.36 and 2.37 and 2.38. And now put the version 5.9 com a 2.38.
Same here with multiple SXT AND GROOVE ethernet port not responding. They show as connected.
rma takes over 3 months. Tell me what to do?
