TikTool for MikroTik
I have just installed TikTool for MikroTik and cant connect my device.
Any idea? Should I set up any firewall rules or anything else?
TikTool is not provided or supported by Mikrotik. Try asking around the developer’s website. http://www.tiktool.com/
So, in this case, what does it mean:
https://itunes.apple.com/mx/app/tiktool-mobile-winbox/id434839992?l=en&mt=8
TikTool - Mobile Winbox
By Kiawe Tech, LLC
As said already, not developed or supported by MikroTik.
:slight_smile:
I dont understand because its declared by Kiawe that TikTool alows to manage/admin MikroTik routers…isnt it?
Ok, now its fine, working on api service 8728 port.
You need to enable api under IP\Service
Sent from my LG-H960 using Tapatalk
I can declare my SuperManagementTool works with Microsoft Server, does it mean it is supported by Microsoft?
This is what i have investigated already. Above.
Have I ever asked if MikroTik supports TikTool? Or if developed it… Just wanted to connect.
Sorry for misinterpretation.
