TILE Broken After Rollback from 7.1.2 to 7.1.1
So I did the 7.1.2 update (from 7.1.1), all tunnels (IPSec) would not come back up..
My first thought was rollback to 7.1.1, because 7.1.1 was working.
After downgrading i have this on the console. Router is remote but I have a network-serial adapter on it..
Resetting chip and restarting.
 logo.bmp not found or data is corrupted
RouterBOOT booter 7.1.2
CCR1009-8G-1S-1S+
CPU frequency: 1200 MHz
  Memory size: 2048 MiB
    NAND size: 128 MiB
Press any key within 2 seconds to enter setup..
loading kernel... OK
setting up elf image... OK
jumping to kernel code
Could not mount ubifs/yaffs filesystem: No such device
[    9.927722] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000000
[    9.927835] CPU: 5 PID: 1 Comm: init Not tainted 5.6.3 #1
[    9.927886]   frame 0: __schedule+0x12288/0x7e0fb8 (sp 0xfffffe007a70fb20)
[    9.929912]   frame 1: __schedule+0x7bb290/0x7e0fb8 (sp 0xfffffe007a70fb90)
[    9.937570]   frame 2: __schedule+0x3ca50/0x7e0fb8 (sp 0xfffffe007a70fbc0)
[    9.945133]   frame 3: __schedule+0x40ca0/0x7e0fb8 (sp 0xfffffe007a70fc80)
[    9.952696]   frame 4: __schedule+0x431a8/0x7e0fb8 (sp 0xfffffe007a70fd20)
[    9.960258]   frame 5: __schedule+0x43270/0x7e0fb8 (sp 0xfffffe007a70fd60)
[    9.967821]   frame 6: __schedule+0x7de800/0x7e0fb8 (sp 0xfffffe007a70fd80)
[    9.975478]   <syscall 94 while in user mode>
[    9.980313]   frame 7: 0x45040 (sp 0x7f88fb30)
[    9.985158] Rebooting in 5 seconds..
Power cycle had no effect.
How can I recover this? Hopefully without NetInstall..
When you see
This means you need to netinstall. I had this happen on my ccr1009 during one of the 7.x updates - the rest of the 7.x updates were fine.
Imo, it looks like something is corrupting the partition/partition table.
In my case it was 7.2rc2 to 7.2rc3. I applied it just to be consistent with my other devices but I made no config changes after 7.2rc2. I don’t know if that was the difference, timing between applying the two updates, just bad luck, or some other bug.
That is what I am afraid of.. Better than complete hardware failure I suppose, but I am 2000km away from it..
Netinstall did restore it.
One thing that messed me up for a long time is that after Starting Services.. (during boot) the
Router OS (version)
Username:
No longer appears on the console.. Just a blank screen with a flashing cursor..
Even pressing Enter a few times had no effect.. Being that I am not there, this really messed me up..
I Netinstalled it a few times, power cycled it, nothing except the flashing cursor..
Eventually hit some keys, which did show and pressed Enter
I was surprised when
Password:
appeared on the line below…
Entering the wrong password did show ‘Invalid’, then went back to the blank screen with the cursor..
System was/is running normally, but it is not displaying the normal login prompt anymore..
Edit: Only for TeraTerm, Putty works normally… Ok.. This is getting weird..
