Time interval
dear all .
i have problem with mikrotik usermanager in rb751 .
i have group with limitation 2hour and after 2 hour , pppoe connection will be disconnected and after that i need
time interval for renew the account in night , for use the connection tomorrow .
please help
thanks all :frowning: :frowning:
first you need to add the function “radius incoming” (coa) so your usermanager actuly can disconnect the user after its amount of time or usage.
then add a script that runs every night with the command “/tool user-manager user reset-counters username” and the user account should be all right to use again.
