Time Out
Hi Guys,
How can I stop session time left while a user shutdown system without logoff,
whenever a user system is down without logoff, I want the system active sessions and cookies to get removed from the router after 1 min
Pls help
I assume you are talking about hotspot? If yes, then set idle timeout to clear unused sessions.
Also in servers profile you can adjust cookie lifetime.
Yes hotspot, Pls, give me the script to do this, and the minimum time i can use
/ip hotspot set hotspot1 idle-timeout=
/ip hotspot profile set hsprof1 http-cookie-lifetime=
set any time values you want. BTW all parameters can be found in the manual:
http://wiki.mikrotik.com/wiki/Manual:IP/Hotspot
