Time Setup ?
I am trying to setup clock in mikrotik but it doesn’t save after adjust, I don’t know if I skipped some steps ?
What do you mean by “save after adjust”?
It doesn’t save when I correct the time and date (adjustment of time and date), my mikrotik time and date is not correct I’m changing it but it doesn’t save after reboot. I hope you understand this time ?
use SNTP/NTP client to syncronize the time. RouterBoards do not have a battery so time is reset each restart
Correct thanks, how to do that ? I enabled SNTP and what address should I provide to primary NTP and secondary NTP ?
You can get the addresses from: http://www.pool.ntp.org/ for your location.
This is what I did simplified from one of the examples on the wiki. http://forum.mikrotik.com/t/date/48636/1
The script is scheduled to run once a day and pick a new primary and secondary NTP server from the pool. Of course if your site already has a local NTP server you can just point at that.
