Time synchronization on devices connected via mikrotik
Hello!
There is a problem: I connect through mikrotik set-top box and TV itself and are not synchronized, although at the mikrotike NTP Gathering set. Does anyone met the same problem? Do oesheniya? Prompt where to dig? :confused:
Many thanks in advance!
it can be that your ISP block the ntp port.
through another router everything works fine. As soon as I connect mikrotik, all devices get off the clock. :frowning:
Are you giving right time servers addresses in the DHCP messages to the clients? Check it.
Do not tell exactly where it should be checked?
I n ip DHCP-server networks. Or let log DHCP message details. Or maybe you block ntp messages from clients .
also local(!!!) timezone should be set CORRECT in your router, since MikroTik didn’t use UTC in RouterOS-powered firmware anymore.
Does not work, like everything everywhere is configured properly, you still do not want to.
1 Configured NTP Client
2 Enable NTP Server
Can configure the firewall that you need? :confused:
Normally you don’t need to have ntp package installed. Just set sntp client and ensure it is set in all clients in the same way.
