Timed Firewall Rules
Hello!
is possible to set a firewall rules to block P2P only from 08:00 to 23:59?
time regulation with NTP server.
10x in advance..
OrCAD
You could script it..
any example for?
10x
on the manual there are examples to do it
RTFM
Maxi
I see the manual and I try to create a script but not work…
I have try to add this line in script submenù:
to enable firewall rule 0
add name=enable-0 source={/ip firewall filter enable 0}
to disable firewall rule 0
add name=disable-0 source={/ip firewall filter disable 0}
this two line are controlled from scheduler manager…but still not work..
any idea to solve it?
many 10x.
Solution for your problem:
http://forum.mikrotik.com//viewtopic.php?t=2112
.. and a proper way to do it:
http://www.mikrotik.com/docs/ros/2.9/ip/filter||0.7123952359947067
Eugene
I have the same problem…
firewall rules don’t disable or enable after scan the comment text!
Any idea?
many 10x
oki I, seem work perfectly with this:
/ip firewall filter {disable [find comment=“lock all P2P”]}
and
/ip firewall filter {enable [find comment=“lock all P2P”]}
10x in advance 4all.
