Timed vouchers
I know the topic has been raised before, but I have got no solution to the problem yet.
I need to be able to produce vouchers with, say, 30 minutes of “airtime”, valid for 48 hours. The airtime should be ‘banked’ when the user logs off.
Currently, a user only gets 30 minutes from the time logged in, whether they log off or not. Our guests requires something more flexible than having to aquire multiple vouchers during a weekend stay.
Is there ANY way this can be done at the moment with userman?
When adding the user specify the uptime-limit 30min and the credit time limit 48h.
thanks uldis,
But where exactly can we specify the uptime limit and credit time limit… this is what i have on my userman for adding a batch of users.. cant see any credit limit… and this is realy vital to us using the usermanager functionally for our hotspot operations… I think MT also needs to look at the number of users that can be printed per page… 3 is such a small number and a waste of printing materials…
Add batch of users
Number of users:
Login starts with:
Additional login prefix:
Rate limits:
Rate limit: RX TX
Burst rate: RX TX
Burst threshold: RX TX
Burst time: RX TX
Priority:
Min rate: RX TX
Uptime limit:
Prepaid:
Show print page
Users per page:
make a credit with 48h with specific price. Then when you create a user specify the created credit name and the uptime-limit 30min.
What exatly you want to see on the printout label?
In next versions you will have option to export the users to CSV and then you can use that information to printout your own labels…
Hot Snot !!
I have been waiting for this one !!
thanks uldis.
usermanager is working great now… cant wait to see the export capability to csv format… keep it up.
v2.9.29 already has CSV export feature :wink:
Thanks, you guys are the best!
