Timeout loading status page
running on a v3.30 I have the “feature” that the status window that pops up after logging in loads and loads and loads and gets an timeout after a while. But when I press F5 (reload) then, it shows the correct status page.
Does anyone know why this first timeout may happen, and what I can do against it?
Thanx, Matthias
Could be a version of a bug fixed in 4.x that confuses the Hotspot when an address-pool is applied. If you have an address-pool configured on the Hotspot, try setting it to ‘none’ and test if it fixes the issue. You can then either upgrade to 4.x where this is supposedly fixed, or leave the address-pool off. The only repercussions to that is losing the ‘Universal NAT’ feature, which - for what it’s worth, personal opinion here - I generally turn off anyway.
I removed the pool from hotspot, so it shows “none” already.
and, does it work now? =)
Ok, my mistake. I ment that I removed it days before already, so it didn’t change and the timeout is still there.
