Timeout pings from router to clients
Hi to everyone,
I’ve recently done some big changes in my network. I moved from one big bridged scenario with 6 distribution nodes, to a routed scenario with 8 different network segments. Everything is working seamlessly from clients point of view (better than before), but it is not the same for me.
My main structure is the following:
Clients (10.20.10.0/24) —))) Node_i <-(10.20.7.0/24)–> UM_Gateway <–192.168.0.0/29–> RB532_LoadBalancing <-192.168.254.0/29-> line1, line2 and a Management Computer to winbox everything and manage usermanager.
From any client in any node I can ping/traceroute to everything (internet or my network, including RB532 and Computer) and get internet connection.
But, I can only ping/traceroute/access my clients from its nearest node and from UM_Gateway. I can’t reach them from RB532 or from Computer.
I can ping/traceroute/access node_i clients’ side Address (10.20.10.1, for instance) from RB532 and Computer. So this problem only appears when node_i forwards traffic.
If I try to traceroute a working client (10.20.10.189 for example) from RB532 or from computer, trace gets stopped at last hop.
[admin@rb532_loadbalancing] > /tool traceroute 10.20.10.189
     ADDRESS                                    STATUS
   1 192.168.0.2     3ms 2ms 1ms
   2 10.20.7.6       3ms 2ms 2ms
   3 0.0.0.0         timeout timeout timeout
   4 0.0.0.0         timeout timeout timeout
   5 0.0.0.0         timeout timeout timeout
[b]Here it stays timing out forever[/b]
Hop 3 should be 10.20.10.189.
  • Node_i default GW: UM_Gateway
  • UM_Gateway default gw: RB532_LoadBalancing and static routes to each node_i (10.20.10.0/23, gw Node_i)
  • RB532_LoadBalancing default gw: Line1. Static route to 10.20.0.0/16 gw: UM_Gateway. Static route to Line2.
  • Computer default gw: RB532_LoadBalancing. Reach Internet through Line1. Has direct ethernet connection to 10.20.7.0/24 but no route to client networks using this interface.
  • Doesn’t matter which node is node_i, I have the same behaviour on all nodes.
I have double and triple checked there’s no firewall rule or queue that could affect my traffic.
Anyone could see an small ray of light or has any small idea about?
You’ve only routed one way - from client to headend.
You know have to route from headend to client. 1 hop at a time.
