Good day…
Is any way to set the timer for the FAN???
I am using router board RB433…
Appreciate for you sharing…
Good day…
the fan connects to the same power as fed to the board. there is no logic to it, it just works. if you want a timer, you have to put some other device in between the fan and the power source, no way to control it from RouterOS
Hi…
This mean if my Power adapter output power is 24VDC then the FAN will run on same voltage (24VDC) ???
looking at the board when Serial is on the bottom, the left fan connector is input-voltage, the right connector is 3.3v
Oh…
Understand. Appreciated for the sharing…
But, how come only the JP804 is not working but the JP803 is working?
there are four Fan connectors actually:
JP801 and JP802 are 3.3V and are alternating (if one stops, other starts)
JP803 and JP804 are 12 or 24V and are also alternating
ie. only two of the four Fans will work at the same time. I updated the RB433 user manual pdf accordingly
