Hi
i want to block someone access in time 13:00:00 to 19:00:00 when i creat firewall timing error is
Couldn’t change firewall rule start time bigger than end time (6)
How i add time
Hi
How i add time
I have no problems adding a rule with “13:00:00-19:00:00”. What exactly are you entering? Post screenshot image
ok
Timing set like this 13:00:00-19:00:00 but client still using net
if the time range crosses midninght, you need to make two rules
19:00:00-00:00:00
and
00:00:00-13:00:00
i want just block internet in this time 1 PM to 7 PM for 1 client
When you add that rule, where does it appear?
Rule #185 is permitting this client’s traffic, if your rule to block traffic appears after, it won’t be seen since the traffic has already been accepted.
work fine to rules
19:00:00-23:59:59
And
00:00:00-13:00:00
Thanks For your support
