Tips for increasing wifi range
hello these are some tips i know about to increase wifi range for indoor devices
tx power= 30dbm
county= super channel
make another SSID for 2.4Ghz
chanel width= 20MHZ
is there any tips?
What device?
Not all support 30dbm and super channel isn't considered legal advice :slight_smile:
Install more access points.
Completely useless:
Increasing the range is completely useless if you don't also increase the range of the devices that need to connect to the access point.
This is ALWAYS the first answer to give...
It's completely pointless to increase the power to place an access point on the ground floor
and have it heard on the fifth floor, when then the smartphone, tablet, or computer,
even if they "hear" the access point perfectly, are unable to interact with it...
Add directional antennas one pointing to the weak room, and one from the weak room pointing back.
Then Tin foil around the entire house, to keep the energy inside.
