Tips on UM ver 5
Hi all,
I am pleased to report UM ver 5 is working great for me. However with the lack of documentation it took a while to solve a couple of issues .
Problem 1. Editing the Voucher Template. Basically i found that the code would be broken when applying changes if they actually saved at all.
Solution, dont use IE. I found the most compatible browser to be Chrome. use a plain text editor to modify the code like Notepad or here is a great online editor http://htmledit.squarefree.com/
Problem 2. LImitations not applying
Solution. Make profile changes using chrome. changes do not allways apply with IE
Disable COA support in router
Other than that it all seems to work fine.
Oh and if a low end router disable logging
FYI I am using UM on an omnitik with Hotspot no issues at all and also a 433 board with no issues Ros Ver 5.18
