TLS 1.3 support in RouterOS
in the config option I only see “only-1.2”. When will be TLS 1.3 available for the services?
I current use 7.14.2 of the firmware.
send Normis booze. Perhaps if he is drunk enough he will approve it. :slight_smile:
After all it was released in 2018 !!!
https://www.a10networks.com/glossary/key-differences-between-tls-1-2-and-tls-1-3/
I would also be interested. Even TLS1.2-only is not “enough” as you can’t block some ciphers…
Has there been an update on this? It is at least possible to disable unsafe ciphers? Where does MikroTik apply TLS? Local login page?
