max connections limit for client in MT web proxy -test is not working at all
also if we try to limit the connections by fire wall rule (/32) it also has no effect when we enable web proxy although it work fine if there is no web proxy . this second time i ask for help but i get nothing
Use 2.9.43 version ‘max-…-connections’ should work there without any problems.
Requests to web-proxy are processed trought ‘input’ chain, proxy replies are processed trough ‘output’ chain. I assume you have created firewall rule for connection-limit in chain=forward, that is responsible for traffic that user passes trough the router.
relly ,thank you mr sergejs
