To Give Vlans to APs With CAPsMAN
Hi, Is there any way to pass vlans to the ssid of the aps with CAPsMAN? I can not get it.
In your CAPsMAN controller, there is a datapath menu. In your datapath configuration, you can set VLAN mode to “use tag” and specify a VLAN ID. You can also leave that out of the datapath and set the vlan mode and vlan id directly on your SSID configurations. Below is a datapath configuration example:
But without local forwarding this doesnt work, the virtual interfaces on router running as capsman has default VLAN ID 1..
Do you need all of the traffic forwarded by the CAPsMAN?
