Hello all, I’m trying to deploy a routed wireless link concerning 4 RouterOS units and 802.11a (5 GHz) signal. As you can see on the lines below, I have tried everything and no positive solution comes out. If some one here in the Forum has a clue I will appreciate for life.
He can run it Smile … in same class but he must put all wlan1 and wlan2 in bridge … Smile … annd then evry link to be in wds … it sould work ..
i hope Smile
Yes its possible, but not the best way of doing it. By bridging you put more stress on the RB, so your links will be slower. But if he wants to bridge he can bridge all interfaces, and run everything on the same subnet. Then there is no routes involved. But I think the link wont be much faster than 2mbps on a rb532 (the figure is a guess, because on a rb 112 its 1mbps). While when routed it will be about 15mbps(that it what one of our link speed it when routed)
