When I execute /tool bandwidth-test command with these parameters from a MikroTik (to which I connect the PC through a ssh connection with public/private keys) to another MikroTik
[admin-ssh@MikroTik] /ip neighbor> /tool bandwidth-test 192.168.1.1 duration=60s direction=both local-udp-tx-size=1500 remote-udp-tx-size=1500 user=admin password=****
It doesn’t end properly…it finishes with the following return string: bad id
status: running
duration: 25s
tx-current: 11.9Mbps
tx-10-second-average: 12.8Mbps
tx-total-average: 18.4Mbps
rx-current: 97.1Mbps
rx-10-second-average: 94.3Mbps
rx-total-average: 59.4Mbps
lost-packets: 8
random-data: no
direction: both
tx-size: 1500
rx-size: 1500
bad id
Has someone had the same problem…? Anyway…please some of Mikrotik guys can confirm whether is that a bug or not…and why is that command failing? Thanks,
