I created two charts with some data source lines. When I open them on a separately window, the tool bar is missing and I cant open the popup menu also. If I add a blank chart and then open it on another window, the next chart window will open correctly showing the tool bar and popup menus when right mouse clicking. edit This problem can be reproduced when opening multiples separately chart windows edit
A side note: dude v2.0b3 seems nicely stable now.
